Leaves LLDP enabled and configured; restores the LLDP timer default values.
all | Specifies all ports on the switch. |
port_list | Specifies one or more ports or slots and ports. |
N/A.
When you issue the global unconfigure lldp, only the LLDP timers are reset to default values. All the configured TLVs remain on the ports remain, and LLDP remains enabled.
When you use the keyword ports, the TLVs for each port are returned to the five default TLVs. LLDP remains enabled.
The following command restores LLDP factory default TLVs for ports 1:4 to 1:8:
unconfigure lldp ports 1:4 - 1:8
The keyword port was changed to ports in ExtremeXOS 11.5.
